RAPtor 350 mods
Old Dec 30, 2005 | 02:43 PM
Raptor350rider14's Avatar
Default RAPtor 350 mods
My raptor 350 has a few things done 2 it. I have new sprocket pipe jet kit cam and k and n. i dont want to spend tons of money or n e thing but i do want a little more power. I also do not want to upgrade to racing fuel, what else should i do.
Old Dec 30, 2005 | 03:07 PM
Timmey27's Avatar
If u want more power out of the bike. You put a 12 tooth sprocket in the front. That will give you some more tourqe. U can also take 150 bucks and buy a fmf header and replace ur stock header. hope i helped
Old Dec 30, 2005 | 03:14 PM
I changed from 13 teeth to 14 to help top end and lengthen gears, so im keeping that. What header should i get powerbomb or megabomb?
Old Dec 30, 2005 | 03:42 PM
Timmey27's Avatar
The powerbomb header.
Old Dec 30, 2005 | 03:51 PM
counterpunch's Avatar
A cam should always be installed with a good piston. Get a JE 10.75:1 piston and an oil cooler set up.
Old Dec 30, 2005 | 04:37 PM
warriorguy22's Avatar
How about an edelbrock carb?
Old Dec 30, 2005 | 05:45 PM
Timmey27's Avatar
I dont think he wants to spend the money on a edlebrock carb.
Old Dec 30, 2005 | 06:53 PM
NBake's Avatar
get a 10.75:1 piston along with some porting, that will increase ur power and taper the powerband the way u want it
Old Dec 30, 2005 | 09:09 PM
DriverDoyle's Avatar
You can look at my mods in my pics and maybe get a few ideals....
First thing you need to do is go with a 15 or 16 front spocket and a 42 or 44 back spocket...
Do not go with a 10.75:1 there not much better than stock.. And if you wanna run race fuel you need a 12:1 Pistion i would not go any higher becouse i have a rappy cooing fan on mine to help keep it cool. If you run anything less than a 12:1 and you run over 103 octan you will burn a hole i the pistion.....
You can go with a Big Bore Kit but there is heating probs with that if you mix it with a 12:1 But thats what i run you just have to be carefull with it....
You Have a stage 1 hot cam you NEED a header pipe.....
Maybe a proflow air kit...
Dyna Programmable CDI box But they run about $500.00....
You Know there is a bunch you can do you just need to decide how much money you want to spend and what you want done.
Old Dec 30, 2005 | 09:25 PM
He said he doesn't want to run race fuel, thats why I reccomended the 10.75:1.
