Need Help
Old Dec 31, 2005 | 05:35 PM
hoozycoozy's Avatar
Default Need Help
I start my Bruin 350 4x4 and it will idle with the clutch all the way on. If I turn the idle down or give it any gas it will choke up and die. I changed the plug, took the jets on the carb out and cleaned them, but I still have the same problem. Is there anything, anyone else can think it might be? I am at a loss. Any help would be greatly appreciated. TIA
Old Dec 31, 2005 | 06:18 PM
recon99's Avatar
Default Need Help
i assume you mean it will idle with the choke on(not the clutch). It sounds like your pilot jet is too lean, or the idle circuit is clogged up
Old Dec 31, 2005 | 08:22 PM
hoozycoozy's Avatar
Default Need Help
What do you mean by idle circuit?
Old Dec 31, 2005 | 08:51 PM
recon99's Avatar
Default Need Help
i consider that to be the pilot jet, adjusting screw, and the pathways in the carb that the pilot jet pulls fuel through.
