Two questions about Warrior
Old Nov 5, 2000 | 03:32 PM
jnholland's Avatar
Just purchased new Warrior and I have two questions I need help with. First, I have heard about the poor airbox design on these bikes.How do I fix this? Second, Is there any way to make the transmission shift smoother and more precise?
Thanks in advance for the help.
Jarrod Holland
Old Nov 5, 2000 | 05:17 PM
EasterEgg's Avatar
The poor design on the air filter is the sealing of the filter to the airbox Pro Design and others make an adapter that allows you to run a clamp on filter for better sealing. It also allows you to remove the lid if you so desire. I purchased a Warrior new in 92 it also had notchy shifting it will get a little better with time but the Yamaha transmissions are known to be notchy unfortunately. HTH
98 Scrambler 500
00 Trailblazer 250
Old Nov 5, 2000 | 08:13 PM
did's Avatar
did
I had a warrior and I adjusted the shift link 2.5
turns shorter and it up shifted much better. The down side to this was it increaced the throw on the down shift slightly.
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
