New to modding a 05 660R have lots of Questions
Old Jan 5, 2006 | 11:34 PM
WildTurkey!'s Avatar
Not Just 101 Proof!
Default New to modding a 05 660R have lots of Questions
I am new to modifying anything let alone a quad. I installed my K&N Air filter and was told to rejet. Is the Dynojet kit any good?? Anyway sounds great after rejetting it but then bought a slip-on exhaust. Do I need to rejet again? And What should the jet size be? And what size sproket should I get and why do I hear about it so much? And should I get a high compression kit so I can smoke my buddies yfz450? What other stuff can I put on my quad? Thanks for the help and sorry about all the questions.
Old Jan 6, 2006 | 01:12 PM
CTracingraptor's Avatar
if your bought a good pipe you shouldnt have any problem smoking your buddies 450's
Old Jan 11, 2006 | 10:29 PM
17528Gecko's Avatar
450's are pretty darn fast. I put a back GYTR pipe, K&N filter, and Dynojet jet kit on mine and it is reliably fast. Don't know if I can beat a 450r.
Old Jan 12, 2006 | 01:45 PM
Cashsraptor's Avatar
Ok here are the answers to your ???'s. Yes I would rejet with the filter and the Dynojet kit is the way to go. I do not think you will need to rejet because of a slip on exhaust. If you will rejet, it will be something small. You do not need a different sprocket with your set-up. If you change to smaller or bigger tires/rims or really go into the engine then you will need to change the sprocket. If I were you I would go with a full exhaust, get full skid plates, and save your money for a 686 kit...........JMO
Here is what I ran in my raptor with a full exhaust:
Main jet: 148 / 150 DJ Needle/Clip position: DynoJet / 4th Pilot:27.5 Fuel Screw (from closed): 2 +/- 1/2 turn
Old Mar 2, 2006 | 09:28 PM
chevyraptor's Avatar
yes you will need to rejet . before u throw all this money on this bike to smoke ur buddies watch what u do dont go to radical or ur reliability will go way down trust me i am on my third rebuild. dont get the real radical cams and dont go to high wit compression i am running 11-1 know and it seems to be fine so far
Old Mar 3, 2006 | 08:00 AM
04RaptorLE's Avatar
As mentioned you will need to rejet.AS to what size I have a full Yosh a KnN and 2 holes drilled in air box and removed snorkel I am running 150/155 jets. I am running stock gearing with my mods and dont have any trouble pulling my buddies modded YFZ as well as others.Now there will be those who say it cant be done,but we are equal riders,we have switched quads,and I was beating his when we were both stock as well.Maybe my raptor is just possessed.Good luck.
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 23, 2015 08:37 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Jul 22, 2015 05:00 AM
blpersinger
Jul 15, 2015 09:56 PM
