Kazuma 150
Old Jan 7, 2006 | 11:52 AM
lswoody's Avatar
Default Kazuma 150
Hello all, new to the forum and new to the atv world. I'm looking at getting a Kazuma 150, the model that has the front and rear racks. I will be using it primarily for hunting puposes and will probably use it some around the yard too. About what size utility trailer will I be able to pull with it. I'm looking at getting a trailer that is 5'x10' with the expanded steel floor to transport the atv and ladder stands to my hunting land. Would this atv be able to handle this size trailer? Also what is the horse power of this atv? Thanks, Scott Woody
Old Jan 7, 2006 | 03:40 PM
billl2099's Avatar
Default Kazuma 150
the towing capacity on the 150 kazuma is 400lbs, proably not enought to haul a 5x10 trailer which i'll guess would weight somewhere beteen 800-1000lbs. the engine is rated at 10 horsepower. i do use mine all the time moving a 6x12 trailer around,so far without a problem. so i know it will haul your trailer ,but for how long and would have problems going up hills and a real big problem going down hills, quads don't have good enought brakes and stability to stop your trailer down a hill. you might get by buying one of those small trailer harbor freight sells, if that would suit your needs. what that trailer you'll be within the haulin capacity of the 150 . also would beable to use it to haul the 150 around too
Old Jan 8, 2006 | 07:24 PM
flexikid's Avatar
Default Kazuma 150
I use my Dingo 150 around the farm and pull small wagons around. I had to change the rear sprocket to a 32 tooth to give it more power. It's not a bad unit for the price and had no problems with it. I agree about the going down hill pulling a wagon (or I should say getting pushed by one) it's tricky stuff.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
michdagh
Sep 19, 2002 05:32 AM
