Question On EdelBrock Singel Carb with 686 Raptor
Finally got the Raptor put back together. I've got a 686 12:1 ratio motor in it. I put a Single Edelbrock Carb on it. After the electrical NightMare, I finding that I'm not getting enough fuel. I understand how everything works but after putting the 21e needle in it and turn it all the way rich with the accerator pump turned all the way up, it's still not enough fuel. This is my question. Can this Single EdelBrock Carb pump enough Fuel for the 686? And if I went back to the stock carbs I believe a 175 180 jets with LTE would be about right? Any suggestions? Thanks Scott
Forget about the Edelbrock Carb not being enough. I put the old carbs back on. It's doing the samething. Since this is a different motor, I'm think there is some serious wire problems.
toonces
Oct 16, 2019 12:11 PM
