Raptor Carb problem...PLEASE help
Old Jan 7, 2006 | 08:25 PM
countryboy28560's Avatar
Default Raptor Carb problem...PLEASE help
Could someone please help me, I just got a used raptor. From a little old lady HONEST, she had got it for her grandson but he got to many DWI"S, so i got a 2003 Raptor for cutting down 30 trees. It has gas coming out the lines on the bottom of the carb when you turn the gas on , then it wont crank by the starter you have to pull start it. And when or if it does crank it cuts right off. Can someone please help a guy out. I am married with 5 kids i need to go riding.You can either leave any help here or emal me at jamesdaddys6@aol.com
Thanks Bob
Old Jan 7, 2006 | 08:56 PM
Turtler's Avatar
Sounds like you got a float stuck. Tap on the side of the carbs with a hammer and see if it jars loose. Better yet, tear it down and clean them out. Sounds like the little old lady let the quad sit with gas in it and you have some varnishing.
Get that quad running and get out of that Brady Bunch of a house you live in to clear your head. Good luck.
Old Jan 7, 2006 | 09:06 PM
I may not be doing something right, i have tore them down and sprayed them out with carb. cleaner twice now, it the float is stuck will that cause me my problems with the engine nort wanting to run and running bad when it does run! Thanks alot for the help
Old Jan 7, 2006 | 11:06 PM
hondabuster's Avatar
If the needle is stuck open, yes itll run like crap. You might have to use some very fine steel wool, or scotchbright, to polish the needle and seat.
Old Jan 7, 2006 | 11:25 PM
raptorider660's Avatar
wo wo wo wo wo hold on a minute since wen does a raptor have a pull start and as for the carbs u gotta take them apart the floats are stuck check them put it back and try it
Old Jan 8, 2006 | 12:14 AM
I am sorry if you miss understood me, it has to be pulled started A rope and a truck. pulled started . Not like a Briggs & Stration lawn mower. Then when it does carnk up it bogs out are just cuts off again. I need all the help i can get!!!
Thanks for all i do get[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 8, 2006 | 12:27 AM
ohhhh my bad then ummmm check the plug same thing happend to my friend we would pull it with another quad for like 30 mins all over but it would just like bog we changed the plug started rite up
Old Jan 8, 2006 | 12:43 AM
Blastermaster's Avatar
well since you say you have allready taken the carbs down and cleaned them, i`m going to venture a guess that the floats are mis-adjusted (as long as they moved up and down freely when you took it apart), now there are a couple of ways to adjust them, you can either just bend the lil tab that the needle rides on up, or you can do it by the service manual, and since mine is a different state i couldn`t tell youthe exact measurement, but i do know you turn the carbs up side down, and measure (if i remeber correctly) from the bottom of the floats, to the bottom of the carb housing
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
