Lt 80 Carb - WAY too much fuel!
Old Jan 7, 2006 | 11:26 PM
WeLuv2Ride's Avatar
Default Lt 80 Carb - WAY too much fuel!
I just cleaned the carb on an '87 LT 80 we recently bought. It had been running good at idle but would not rev in the higher rpms good without bogging. After putting the carb back on, I left the air filter intake hose off. The motor idles great. I rev the motor and fuel is blowing out through where the intake hose attaches on the front of the carb. The motor bogs down bad when you give it throttle. What are some ideas on why so much fuel is going through? Thanks
Old Jan 8, 2006 | 12:57 PM
LT80's Avatar
LT80 Expert
I'd clean the carb again to make sure it's clean.
I'd prolly check the reed while the carb is off.
Old Jan 8, 2006 | 07:56 PM
WeLuv2Ride's Avatar
Yea, I'm going to clean the carb again. After seeing all the funk inside when I cleaned it the first time....Talk about nasty. I had to use my Dremel with a wire brush to get it cleaned up! Since the problem is not in the idle, I should be looking in the main jet area for debris, right? Wrong? What do I look for in the reeds? How do I know if they're good or bad? I'm new to 2 -strokes, so bear with me.
Thanks for the help.
Old Jan 9, 2006 | 01:01 PM
LT80's Avatar
LT80 Expert
The reed is a metal piece that sometimes crack/break.
As far as the carb, make sure you remove the lil brass seat that the needle sits in. Other than that just a double check that it's clean..
We'll gom from there.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 9, 2006 | 09:13 PM
WeLuv2Ride's Avatar
UPDATE: after cleaning the carb thoroughly 3 times, it still was getting too much gas. I also looked at the reeds and they looked fine. Feeling the heat from a 7 year old little girl who couldn't understand why I can fix everything else around here and not her 4 wheeler.....I took the plunge and bought a new carb and reeds. PROBLEM SOLVED! Her faith has been restored and my wallet is a little lighter.
2 weeks pass and I just HAVE to know what's up with the old carb. I take the slide out and guess what? The needle is set on the 5th position. DUH, another lesson learned. I haven't put it back on yet to check it but I would think that was my problem. I will update whenever I get around to it.
Old Feb 10, 2006 | 02:04 AM
Kendoo67's Avatar
I am having simmiler problems I am going to rebiuld the carb , Where should the clip be on the needle , you said it was on the fifth spot is that fifth from the top or the bottom. Also were your reeds bad or what did they look like?
Thanks
Old Feb 10, 2006 | 03:43 AM
WeLuv2Ride's Avatar
Thanks
As the needle sits in place, the top groove is #1 and the bottom is #5. Stock setting is #2, however I placed my new carb setting at # 1 since these things seem to run a little rich in stock form. Some people put in smaller main jets as well 87.5 or 90. Stock jet is 92.5 I think. My reeds looked fine. I compared them to the new ones and saw no difference in clearance or anything. But I was on a mission, I was going to fix it!
Old Feb 10, 2006 | 08:24 AM
Kendoo67's Avatar
I will try that and let you know, thanks alot and thanks to LT80 for all his help.
Aitch
Jul 21, 2015 09:40 PM
micheleLeigh
Jul 12, 2015 02:50 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
