ATV shootouts - 49 state Raptor or Cali' version
Old Nov 6, 2000 | 10:48 AM
garyc660R's Avatar
Anyone Know?
Old Nov 6, 2000 | 03:23 PM
xtreme165's Avatar
The cali version is alot slower stock due to emission regulations. 49 state model is the way to go1
Old Nov 6, 2000 | 05:00 PM
Bigdog's Avatar
What exactly is the difference between Cal/49 state versions. I heard someone on here say it was just the exhaust pipe, but I don't believe that is it. There is nothing you can really do to an exhaust short of putting on a cat that is going to effect emissions. Does anyone know the exact details on what the difference is???
Old Nov 6, 2000 | 05:20 PM
Grandpa's Avatar
I own a Raptor that was purchased in NV and my friend has one that was purchased in CA. They are identical from all outward appearances. In a race they are also identical. In the sand they are identical. Ride one or the other and you cannot "feel" a difference. I think the reason for this is that they are identical but thats just my 2 cents!
Old Nov 6, 2000 | 06:49 PM
ScoobyDFW's Avatar
then why are we seeing dyno runs at 33HP and 38HP?
Old Nov 7, 2000 | 08:40 AM
garyc660R's Avatar
That is the question.......why are we seeing 33hp to 38hp? Also, it seems that the pipe manufacturers are either getting around 5-7hp or 10-12hp. It seems one is building a pipe for the Cali' version and another is piping a 49 state version. If this is true....the difference appears to be in the exhaust system.
Old Nov 7, 2000 | 09:35 AM
bash's Avatar
If there is any difference, it is the jetting. The Cali model could be jetted different (probably leaner) than the 49-state model. Once they are jetted correctly for whatever mods that they have, they should turn out similar numbers.
Old Nov 7, 2000 | 10:19 AM
garyc660R's Avatar
True...but the leaner jetting would have to be in the main jet. It seems a lot of the 49 state versions are already lean on the bottom (mine for example).
Old Nov 7, 2000 | 10:37 AM
bash's Avatar
Gary,
Maybe I'm missing something here, but the low end lean jetting should be mostly caused by a lean primary jet.
Top HP numbers would differ more because of a main jet being too lean. If Yamaha was to lean out the engine some in the name of emissions, they would probably do it on the top end of the RPM range where it wouldn't really affect rideabiltiy.
This is probably more than likely the case since we are seeing about a 5hp difference on top and the low end seems to be pretty much the same on most of them.
Old Nov 7, 2000 | 11:57 AM
garyc660R's Avatar
I don't think you're missing anything. I believe I was a little vague in my previous post (meant the same thing as you just posted). By the way...how long did it take your dealer to get your intake boots in?
