Raptor 350 re-jet?
Old Jan 16, 2006 | 09:38 AM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
Default Raptor 350 re-jet?
Ok, so I want to added on a GYTR air filter with a prefilter and removed the airbox lid, my friend says I should rejet since I took the air box lid off. Need to rejet?
Old Jan 16, 2006 | 02:49 PM
hondabuster's Avatar
Most likely.
Go by the drivability symptoms. Is it hard to start when cold? Is there a bog or backfire? Does the engine miss? Does the engine surge at steady throttle openings?
If you have any of those, or others, then it needs rejetting.
Old Jan 17, 2006 | 11:54 PM
recon99's Avatar
You'll have to rejet. The stock 350 airbox and snorkel is pretty darn restrictive. Just removing the airbox lid and rejetting on a yfm350 will give you close to the power gains you get from a good exhaust. When you let that much more air into the motor you also need to add more fuel to get the biggest power gain.
Old Jan 18, 2006 | 12:06 AM
ATVrider89's Avatar
More fuel meaning keep it full at all times? Or as in begger jets? I already ordered GYTR jets.
Old Jan 18, 2006 | 09:12 AM
recon99's Avatar
I mean making the fuel mixture richer. A bigger main jet, and you might have to richen the needle and the idle mix too.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
