Heel Clicker Clutch?
Old Jan 16, 2006 | 03:11 PM
problem's Avatar
Default Heel Clicker Clutch?
Someone tell me about this Heel Clicker Clutch....Does it really work I have the 500HO mostly into trail riding some mud and hunting...
Anyone got any imput on the goods and bads of this clutch kit??? and most of all is it worth the money and time?
I have a trail mower that i use for mowing.....
Old Jan 16, 2006 | 03:22 PM
zerowick's Avatar
try this
Cob is the guy you want to talk to. plenty of threads on the link for you to comb through. good luck.
Old Jan 16, 2006 | 04:08 PM
wayout's Avatar
i have one in a sportsman 400 2004,i like the lower rpm engagement but don't like hard backshift' it backshifts to quick it jerks you backwards.
Old Jan 16, 2006 | 05:40 PM
JustPlainAl's Avatar
I had the H/C in my '04.5 500 HO and it was super for trail riding. (See my website for pics) The lower engagement and better acceleration over the stock weights was super. Loved it so much, I put the Heelclicker in my new 800 when I traded up. The setup is easy, and is the best performance investment I made.
Old Jan 16, 2006 | 06:41 PM
zerowick's Avatar
not quite sure I understand you, could you elaborate on your comment?
thanks.
Old Jan 16, 2006 | 06:44 PM
zerowick's Avatar
how do you think it would perform from a utility perspective; heavy hauling?
Old Jan 16, 2006 | 08:15 PM
problem's Avatar
I am with ZERO how do you think it would perform in a Utility Perspective? and how does it work when you run in low range...
looks like as of now there is good points.....
Old Jan 16, 2006 | 09:46 PM
The Heelclicker will grab the belt tighter at a lower rpm, and slip the belt less. In low gear you will have a real stump-puller. I've pulled my 4-wheeler trailer loaded with logs with no worries about burning the belt. A trail mower pulled at walking speed should be no sweat. The H/C is great for low-end performance without losing top speed.
Old Jan 16, 2006 | 10:32 PM
problem's Avatar
So is the H/C hard to install......And the only place i have found them is at heelclicker.com is this the only site???
Old Jan 16, 2006 | 10:45 PM
okiedude's Avatar
They are pretty simple to install. I have one in my 500 but took the one im my 700 out. I took it out because for some reason, it didnt help my 700 at all. My buddy bought a 700 same day I did and with the heelclicker in, he beat me in every catagory you could think of. I took it out and we are back to equal. I am not bashing heelclicker,since I still have one in my 500, but it didnt do me any good for my 700(the "stock" feel is great on this quad).
