stupid stickers
Old Nov 7, 2000 | 09:55 AM
scr500's Avatar
Does anyone know any way to remove those stupid warning stickers other than the tedious "hair dryer/slowly peel/pick with your fingernail" method? Any help would be appreciated. SEC
Old Nov 7, 2000 | 10:23 AM
A400L's Avatar
There are several. I prefere to spend a few $$ and go to a car wash. Use the setting for "wash/soap" as it seems to have the warmest water.
Old Nov 7, 2000 | 11:46 AM
weltmaster's Avatar
just got done rippin em off my oo scrambler 400 4x4. i found out if you use a heat gun ,not a hair dryer, and [warm] the plastic from behind the sticker, they come off in ONE piece. so ie, instead of melting the sticker which makes it weak, warm the glue only!! from behind the sticker!! hope this helps.
Old Nov 7, 2000 | 12:09 PM
MEANGREENMACHINE's Avatar
I use wd-40 and spray it all over the sticker. Let it soak for a few minutes and then peel it off. It works pretty good.
Old Nov 7, 2000 | 12:57 PM
WIscrambler's Avatar
Hey~
If you have a strong enough pressure washer, you can usually blast them right off. I used a 2800 psi washer and they came off easily. I'm sure a hot water pressure washer would do the task even easier.
Old Nov 7, 2000 | 08:53 PM
stevescrambler's Avatar
Take a rag with brake fluid on it and wipe the sticker real good. Let it sit over night and then peel them off. It works great.
Old Nov 7, 2000 | 11:52 PM
SWAC1's Avatar
I got so frustrated, I tried a window scraping razor blade system, worked okay for a while, but I gave my sportsman a few cute "NICKS". More like gouges. The brake fluid works good, leave a rag full of the stuff on it overnight, next day they come off easy.
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
bigred20653
Aug 31, 2015 12:41 PM
chris7420
Jul 30, 2015 02:04 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
