Rear Spring Adjuster on 1999 Scrambler
Old Nov 7, 2000 | 11:00 AM
Scramblin's Avatar
Has anyone else had problems with the rear spring plastic adjuster nut stripping the threads out? I've had 5 new adjuster nuts and 1 new shock replaced under warranty. After the warranty ran out, I installed 2 adjuster nuts back to back and it seems to be holding for now.
My main question is does anyone know it there is an aftermarket metal adjuster that will fit on this shock? If not there should be! The Polaris rep had the dealer try to install a 2000 model shock, which if you'll notice has a metal adjuster (which would indicate that Polaris was aware of this design defect). But, the 2000 model shock was way too long.
Any input would be appreciated,
Scramblin
Old Nov 7, 2000 | 01:51 PM
Farmr123's Avatar
Two things come to mind. Take one of your old adjuster nuts to someplace that deals in dirt bikes. They have used a metal nut for years. You might just get lucky & find one that will fit. The other alternative would be to see if a machine shop could make you one. No idea on cost. Seems for what these machines cost they could have had a metal one from the start.
Old Nov 12, 2000 | 12:30 PM
Daks's Avatar
yes my 99 sc500's stripped as well. If you look at a 2000 model they switched over to a metal one. Yes it does fit and it cost about $60
Old Nov 12, 2000 | 03:10 PM
Scramblin's Avatar
The 2000 model shock does not fit, been there already. It sets the rear of the machine up about 4 inches and the spring binds pretty severly with the frame cross member behind it. Polaris moved the shock mounting postions on the 2000 models to get more rear axle travel with the longer shock.
Scramblin
Old Nov 12, 2000 | 10:26 PM
Farmr123's Avatar
I think Daks meant that the 2000 adjuster nut will fit your machine. At least that is how I read it.
Old Nov 13, 2000 | 11:48 AM
Scramblin's Avatar
The threads for the adjuster nut on the 2000 model have the threads cut into the shock body itself. The 1999 has an aluminum piece that fits over the shock.
Scramblin
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 13, 2015 05:11 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
