high compression piston kit
Old Nov 7, 2000 | 02:02 PM
warr's Avatar
what would be more reliable and have a more impact on speed and acceleration on a yamaha warrior either a high compression piston kit or a big bore kit.
can you explain me what each one does.
Old Nov 9, 2000 | 02:06 AM
rhino99's Avatar
Both.
The big-bore kit would require a new piston anyway, and if you are getting one, you may as well get a high compression piston.
However, a cam will probably make more difference than either, for a cheaper overall cost.
Old Nov 9, 2000 | 04:36 AM
PHATTYBOY's Avatar
THE CAM WOULD PROBABLY HAVE MORE IMPACT ON ACCELERATION...THE BIG BORE FOR MORE OVERALL SPEED....THEY KIND OF WORK TOGETHER...MOST LIKELY
JUST A CAM WOULD BE CHEEPER...
Old Nov 12, 2000 | 08:57 AM
KawasakiKid's Avatar
A big bore kit will increase the engine's displacement. Basically allowing the engine to consume more oxygen and fuel. The more oxygen and fuel an engine can burn the more HP you'll obtain.
Increasing the compression ratio increases cylinder pressure. Basically, squeezing the fuel and air into the cylinder head more than before.
Think of it this way, take an M80 firecracker, set it on the ground and light it. Boom right? Well set it inside a small coffee can (can top facing ground) Bigger BOOM. Why? Because you're containing the same explosion in a smaller area, which results in a more powerful explosion.
Also a higher compression ratio will burn fuel / air more effeciently. Remember though, any comp ratio over 10:1 will require a higher octane fuel. 93 octane would be the minimum for 10:1
Changing CAM specs (lift, duration, etc.) changes the affect of the intake and exhaust valves. A higher lift cam will open the intake valve more, which results in more fuel entering the engine. A higher duration leaves the valve open longer.
I'm sure you've heard a muscle car idle? It sounds real loapy or choppy. That's because the CAM is leaving the valves open longer (to increase fuel consumption) and if they are open longer, they will have to close faster so that the piston will not smack them, so they close abruptly. This is what gives a muscle car that type of idle.
There is your Engine 101 for today!
Old Nov 12, 2000 | 12:13 PM
slickster's Avatar
Nice explanation.
The Slick
Divergent12
Dec 30, 2017 08:33 PM
Mikegriff92
Technical and How-To Articles
Oct 26, 2015 02:40 PM
manuelrivera
Aug 8, 2015 04:34 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Jul 29, 2015 10:57 PM
