length, height,width everything?? please help
Old Jan 22, 2006 | 03:08 PM
1988fast250x's Avatar
Default length, height,width everything?? please help
ok i am wanting to know everything about the 450r and the 400ex all the dementions please! i really really need this... center wheel to center wheel so any help would be great...
Old Jan 22, 2006 | 04:29 PM
getdrunk's Avatar
heres the 450r
Manufacturer: Honda
MSR: $6499
Model ID: TRX450R
Model Year: 2004
Type: Sport
Emissions:
Available Colors: Red
Honda TRX450R Engine:
Engine Type: 450cc liquid-cooled single-cylinder four-stroke
Bore and Stroke: 94.0mm x 64.8mm
Compression Ratio: 10.5:1
Valve Train: Unicam;four-valve
Carburetion: Keihin 42.0mm with throttle position sensor (TPS)
Ignition: Solid-state CD with electronic advance
Honda TRX450R Drive Train:
Transmission: Five-speed
Final Drive:
Honda TRX450R Suspension:
Front Suspension: Independent double-wishbone with Showa shocks, featuring adjustable spring preload, rebound and compression damping; 8.4-inch travel
Rear Suspension: Pro-Link with single Showa shock featuring adjustable spring preload, rebound and compression damping; 9.0-inch travel
Honda TRX450R Brakes:
Front Brakes: Dual hydraulic 174.0mm discs with twin-piston calipers
Rear Brake: Single hydraulic 190.0mm disc with single-piston caliper
Front Tire: 22 x 7-10 knobby radial
Rear Tire: 20 x 10-9 knobby radial
Honda TRX450R Dimensions:
Rake: 0 degrees
Trail:
Wheelbase: 49.2 inches
Seat Height: 32.6 inches
Dry Weight: 350 pounds
Fuel Capacity: 3.2 gallons
400ex stuff
Base MSRP: $5,299
Specifications:
ENGINE
Engine Type 397cc RFVC air-cooled dry-sump single-cylinder four-stroke
Bore and Stroke 85.0mm x 70.0mm
Carburetion 38mm piston-valve with accelerator pump
Ignition Solid-state CD with electronic advance
Starter Electric
DRIVE TRAIN
Clutch Manual
Transmission Five-speed
Driveline O-ring-sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension Independent double-wishbone with Showa shocks, five-position spring-preload adjustability; 8.2-inch travel
Rear Suspension Pro-Link fully adjustable single Showa shock; 9.1-inch travel
Front Brakes Dual hydraulic 174mm discs
Rear Brake Single 220mm disc
Front Tires 22 x 7-10 knobby radial
Rear Tires 20 x 10-9 knobby radial
DIMENSIONS
Length 72.2 inches
Width 45.3 inches
Height 43.7 inches
Wheelbase 48.4 inches
Seat Height 31.9 inches
Ground Clearance 4.3 inches
Turning Radius 10.5 feet
Dry Weight 375.0 pounds
Fuel Capacity 2.6 gallons, including 0.4-gallon reserve
OTHER
Available Colors Red, Yellow
Model ID TRX400EX
Old Jan 28, 2006 | 04:32 PM
maddog56's Avatar
Try showing a little initiative and effort, all of that information is availible on the Honda website just like it has always been for these and just about every other factory atv.
Old Jan 28, 2006 | 04:34 PM
why?? this was faster!
Old Jan 28, 2006 | 05:18 PM
maddog56's Avatar
An hour and 21 minutes was faster than loading the 2 spec pages from honda's website? didnt think so.
Old Jan 28, 2006 | 09:10 PM
getdrunk's Avatar
i looked it up. i copied n pasted. it took like 10 minuts. ill do any thing to help my quad bros out
Old Jan 28, 2006 | 09:17 PM
and i thank you for that! honestly
badgerboy1
Sep 26, 2017 06:11 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
