Axle diagnosis
Old Jan 24, 2006 | 06:18 PM
Bluethumb's Avatar
Default Axle diagnosis
I have a problem with my '03 400. When in 4X4, I can hear a clicking, or snapping sound coming from the right front wheel area. I removed the wheels and checked the ball joints, and they're a little worn, particularly the bottom ones. I also looked at the CV boots, and they are in good shape, with no rips, tears, or abrasions. I'm trying to narrow it down to a ball join, bearing, or CV joint. Any ideas??
Old Jan 24, 2006 | 07:30 PM
v2rider's Avatar
Im pretty sure clicking sounds refer to bearings most of the time but I am not a mechanic. Bear might know more. Otherwise good luck
Old Jan 24, 2006 | 08:31 PM
Bear4570's Avatar
If it was a bearing, it should click any time the wheel turned, the same for the CV but some times that just isn't the case. When power is on there is more stress in the bearing and CV, however I would suspect a CV. as the most likely noise maker. The bearing may also be going bad or be bad because water can get in the from the wheel side of the assembly. You have to take it apart to check.
Old Jan 25, 2006 | 12:42 PM
rango726's Avatar
in a car or truck that would be cv shaft also in a car or truck if it were a bearing you would be able to move the tire up and down it will have slop in it but but that also applies to ball joints and tie rods a bearing would be a grinding noise even if you werent in 4wd a ball joint or tie rod would pop while hitting bumps or turning at least in a car or truck anyway
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
