engine ice!!
Old Jan 26, 2006 | 07:54 PM
cloftis's Avatar
Default engine ice!!
what is the recommended flush or drain of this product!!! never would mix with any other product do to its make. has only been in bomb for 7 months. not worried about freezing, live in az. but what about the properties for cooling? carlton
Old Jan 26, 2006 | 08:51 PM
2BIG2BFAST's Avatar
i flushed my system with water about 6 to 7 times.
Old Jan 26, 2006 | 08:55 PM
cloftis's Avatar
how long from installing this product did you do so? if it looks good leave alone?
Old Jan 26, 2006 | 09:12 PM
2BIG2BFAST's Avatar
are you going back to regular antifreeze or are you just wanting to know how often i flush my system
Old Jan 26, 2006 | 09:16 PM
cloftis's Avatar
my question is most people change radiator fluid, in the ds650 yearly or when? and when would engine ice need to be changed or does it ever?
Old Jan 26, 2006 | 09:22 PM
2BIG2BFAST's Avatar
im half retarded and i run it in all three of my bikes the 2 that get ridden and ridden hard i change every year. and since the other one never gets ridden i have not yet changed it and its right at one year right now. 05x and it might have 20 hours on it and thats probaly weigh over from what it really has. if you ride hard and alot and its hot where you ride once a year. at 40 dollars a gallon use it sparingly
Old Jan 26, 2006 | 09:27 PM
cloftis's Avatar
appreciate your info 2big, ii will go ahead and change in a few months!!!!!
Old Jan 27, 2006 | 12:38 AM
IdahoVinnie's Avatar
In most cases, coolant should be checked for 3 things: debris in the fluid, proper freeze point, and ph balance. IMHO, if it passes these 3 categories, there is no need to change it (unless you just want to).
If there is any other specific criteria, I would be interested in knowing of it.
Old Jan 27, 2006 | 05:18 AM
DSexpress's Avatar
IT will all depend on how much this bike is run as to how often you change it. Kinda like oil but not as often. LOL! I run it in my drag bike until I lose enough on the ground....then I change it. [img]i/expressions/face-icon-small-wink.gif[/img]
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
