Oil in water
Old Jan 27, 2006 | 01:05 PM
J126's Avatar
Default Oil in water
purchased a 2002 700 twin from my neighbor. I just noticed 1/8 " of oil in the coolant bottle. I emptied and cleaned the bottle. There was also a film of oil in the radiator that I also removed. After about 6 hours of riding It's back, more oil. He had the water pump changed under recall???...he said. Could oil be in the cooling system from the water pump change? I'm going to drain and refill the system this weekend. There is not water in the oil. What troubles do I have?
Old Jan 27, 2006 | 03:56 PM
HondaSlayer's Avatar
Ive heard of simialar problems in older car engines, its usually from a crack between the bottom end and a watter channel in the block....which would be a worse case scenario
Old Jan 28, 2006 | 01:40 PM
gunman457's Avatar
I don't know anything about that motor, but maybe you need to put some silicone on the water pump bolt threads. Maybe the bolt holes go through to the crank case. Just my two cents.
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
