1987 Yamaha 350 flooding
Old Jan 28, 2006 | 11:37 AM
RU's Avatar
RU
Default 1987 Yamaha 350 flooding
I have a 1987 Yamaha 350 that is flooding out. I replaced the needle and seat and float which helped, but it is still flooding. Any suggestions on what to look for???
Old Jan 29, 2006 | 08:17 PM
rruser's Avatar
Does it just flood itself out sitting overnight? or does it flood when trying to ride?
Old Jan 30, 2006 | 11:51 PM
RU's Avatar
RU
It used to flood out just standing but the needle and seat and float took care of that. Now once it starts and runs it floods out.
Old Feb 1, 2006 | 12:46 AM
rruser's Avatar
At what throttle position does it flood out? Throttle position plays a big part in finding carb problems, as you will see below. Do you have an aftermarket air filter or pipe on the ATV? If the last owner had it jetted rich for a high flow filter or exhaust, replacing one of them with a stock park could cause the jetting to be too rich. It could also be as simple as a dirty air filter or broken choke. I have some info below to help you find the problem.
Here are some guides to jetting. Searching this forum will come up with many more.
http://www.exriders.com/techarticles/jetting.html
http://justkdx.dirtrider.net/printcarbtuning.html
Below are the specs for a Warrior 350 with a stock air filter and exhaust.
Main Jet: #145 This effects how you run from high mid to full throttle.
Needle Jet: 5J18-3 This effects how you run in the mid range. The lower the clip, the more fuel you get.
Pilot screw: 2 turns out. This effects how you run at idle and just coming off idle
Customer Service #1
May 15, 2020 08:46 AM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Sep 17, 2015 03:06 AM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Sep 8, 2015 10:51 AM
