yamaha bear tracker wire diagram
Old Jan 28, 2006 | 11:10 PM
kings's Avatar
Default yamaha bear tracker wire diagram
any one know where i can get a yamaha bear tracker wire diagram
Old Jan 28, 2006 | 11:20 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
yes
Old Jan 28, 2006 | 11:25 PM
Speedy2222's Avatar
this may work....
try this.. hope this is what you wanted.
Old Jan 29, 2006 | 01:12 AM
hondabuster's Avatar
What year?
Old Jan 29, 2006 | 01:50 AM
kings's Avatar
It is a 2001 and i need a wire digram that shows the color of the wires and where they go to becasue i have a light blue and a green/blue wire that are not connected. The lights are really dim and the eletric start will not work, none of the nutreul lights or reverse light work on the panel with the key.
Old Jan 29, 2006 | 02:27 AM
Sorry, I have the timberwolf wiring diagrams, but thought i had the beartracker.
They are probably similar enough though. On the timberwolf..the blue wire is between the light switch and the tail light.
The green /blue is between the reverse light and the reverse switch.
Hopefully someone else comes to the rescue.
I sent a PM
Old Jan 31, 2006 | 08:45 PM
kings's Avatar
same here when it gets to the air box the two wires are hanging does it show where they plug in is it possible you could scan it and send it to me the digram through email maybe. because the pull start broke off and i need to fix this so
Old Feb 1, 2006 | 04:53 PM
I sent a PM
Old Dec 23, 2011 | 06:20 PM
jeff0319's Avatar
Default 2001 Yamaha Bear Tracker
I recently bought my son a 2001 Bear Tracker. The thing has been running ok. We ran into a problem recently with the electric starter not working. The neutral light would not come on and the starter would not work. After looking around, a wire was hanging down on the left side of the machine. It is a green wire so I assumed it was a ground. When you touch it to metal, the neutral light comes on and the electric starter works. I could not find where it was originally attached, so I put a connector on it and attached it to the frame. Now, everything works, but the neutral light stays on constantly. Is this going to hurt anything? Where should this wire be attached? Does anyone have a wiring diagram? Any thoughts would be appreciated!
Old Dec 25, 2011 | 03:27 PM
SeniorCitizen's Avatar
This is not the year you want - 2 years earlier - but should be the same
This drives me crazy - I have provided links to many manuals - on several forums -Once in
while I get a TNX but I see tons of downloads. End of rant :-)
I hope this helps !
Merry Xmas
1999 BEAR TRACKER YFM250X.pdf
