Won't Start Help!!!
Old Jan 29, 2006 | 08:06 PM
bomber4life's Avatar
Default Won't Start Help!!!
04 DS 650, Have Fuel, have compression, no spark. Is there a way to test the pick up? How about the CDI. The CDI is a e-bay special with no name, so it is suspected to be the culprit, but I just replaced the Sprag gear, so by moving everything, I wonder if I screwed the pickup. Just wanting to know how to test, any info will help. Thanks, Justin
Old Jan 29, 2006 | 10:12 PM
crazypainter's Avatar
Make sure you plugged all the plugs back together from the stator and pick up, I forgot once.
Old Jan 29, 2006 | 11:43 PM
Dingo2's Avatar
bomber..I just went thru the exact same problem. Do a search for the thread I started named, sprag clutch change, now won't start. My guess is you have the same problem I had, there's good advice on that thread...got my runnin!
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
