400ex Swing arm
I was wondering if anyone else has had a problem with their swing arms cracking. I just swapped frames and while i was cleaning my swing arm i found that it was cracked right behing where the rubber chain guide bolts on. has anyone else had a problem with this. if so what did you do to fix it other than buying a new swing arm. I was wonderin if you guys thought welding it would hold? Thanks for the input.
i read that 400ex's are prown to breaking stock swingers. but put it this way. i run a stock swing arm and i been flat landing at 15 feet high of air all last summer and no problums. and i drove for at least 1 hour a day hitting jumps no problums. and it was stock shocks with the rear soft as can go. so i say its good n light.
