400ex Swing arm
Old Jan 30, 2006 | 01:37 PM
HondaMan440ex's Avatar
Default 400ex Swing arm
I was wondering if anyone else has had a problem with their swing arms cracking. I just swapped frames and while i was cleaning my swing arm i found that it was cracked right behing where the rubber chain guide bolts on. has anyone else had a problem with this. if so what did you do to fix it other than buying a new swing arm. I was wonderin if you guys thought welding it would hold? Thanks for the input.
Old Jan 30, 2006 | 04:28 PM
TRX888's Avatar
Ive posted this before, ive welded both of my stock and my roll design and both have held up to heavy motocross up to 30 races a year so welding if its done properly should be fine
Old Jan 30, 2006 | 06:03 PM
rhinomxer's Avatar
That's a scary thought. I'm stripping my EX sometime soon to redo the frame...hope my isn't cracked.
Old Jan 30, 2006 | 10:26 PM
getdrunk's Avatar
i read that 400ex's are prown to breaking stock swingers. but put it this way. i run a stock swing arm and i been flat landing at 15 feet high of air all last summer and no problums. and i drove for at least 1 hour a day hitting jumps no problums. and it was stock shocks with the rear soft as can go. so i say its good n light.
fd24
Jan 16, 2019 08:59 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
