HMF jetting
Old Jan 31, 2006 | 02:20 AM
XracerZ's Avatar
Default HMF jetting
i got a 04' 450R with a HRC kit installed in it. i live in Minnesota, and i just ordered a HMF slip on and it should be here tomarrow. now my question is. what exactly do i need to jet this thing? guys at HMF said to use a 180-185 main jet, and the airfuel screw should be 2.5-3 turns from closed.... where do i get a 180-185 jet from? how much? is it hard to install the jet?
is this all i need to jet the main jet and the airfuel?
Old Jan 31, 2006 | 04:02 PM
White7's Avatar
Default HMF jetting
Yep should be all you need,the HRC kit comes with a 185 already so i assume you have a 185 main in there
as far as changing it ,theres a hex on the bottom of the carb(13 0r 17 mm I forget) turn your gas off unscrew that and the jet is right there,with a 1/4" ratchet and socket you can pull it and put the new on in ,in less than 5 min.
Old Jan 31, 2006 | 06:13 PM
XracerZ's Avatar
Default HMF jetting
if the HRC kit came with a 185 jet. would i need to get different jet since im getting a new exhaust for it?
Old Jan 31, 2006 | 08:21 PM
White7's Avatar
Default HMF jetting
The 185 should be fine
Old Jan 31, 2006 | 09:52 PM
XracerZ's Avatar
Default HMF jetting
so even though right now my quad is tuned correcty with an HRC kit, by adding a new exhaust it will still be turned right with no jetting?
Old Feb 1, 2006 | 08:53 PM
White7's Avatar
Default HMF jetting
Yes with an HRC kit and a slip on OR full system your jetting will be 180 to 190,so the 185 is right down the middle of the road
Old Feb 2, 2006 | 12:51 AM
XracerZ's Avatar
Default HMF jetting
just got the pipe today, put in on, took about 2 min. started it up.. wow. i thought it was fast before, now its insane fast, i never knew just by adding on an exhaust would make such a difference. it seems like it needs no tuning at all. but yea, it has soooo much more low end snap now. it never had that before. usually it didnt have much for low end, but once it was reved up it went fast, now its fast all the way though the rpms. when i was going down the road i couldnt keep the front end down. and i love the sound as well. [img]i/expressions/face-icon-small-smile.gif[/img] that loud throaty roar ( im glad i dont have neighbors) every penny of it was worth it.
if anyone is looking for an exhaust go with HMF awesome awesome pipe.
this kinda ended up being a review of it but oh well im still suprised that it needs no tuning. maybe it wasnt tuned right in the first place with the HRC kit, becasue it just seems like this thing has a new engine in it, its insane how snappy it is now.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
