Question for Mike
Old Feb 1, 2006 | 03:32 PM
gonicguns's Avatar
Default Question for Mike
Mike- Question referring to the rear caliper on the 200x.
I have been doing some light riding (front brake only), I had time to add on the rear brake assembly recently. As I filled the unit with brake fluid, and pumped the pedal, fluid was leaking out the back side of the piston (around the shaft sticking out the back. The piston does not move. Each pump you see a flow of brake fluid.
What do you think is the problem?
Thanks.
Old Feb 2, 2006 | 12:57 AM
1988TRX250R's Avatar
Sorry that my name isn't Mike, but I actually worked on the rear brake caliper of one of these today. You said fluid was leaking out the back of the piston, I'm assuming you mean by where the parking brake mechanism attaches. There is an o-ring that goes around the shaft of the piston. It's either damaged or not installed.
Old Feb 2, 2006 | 02:52 AM
ThrashAndCrash's Avatar
Thanks.
Did you remember to buy the "parking brake block-off "plate ????????? {so you guys know...I'm the Mike he was looking for [img]i/expressions/face-icon-small-happy.gif[/img])
Old Feb 2, 2006 | 09:22 AM
gonicguns's Avatar
Oh yea... We talked about that! I will get one found and installed. Thanks Mike and 1988.
Old Feb 2, 2006 | 09:34 AM
gonicguns's Avatar
Did not mean to be so dumb, I knew that but was buried in the depths of the mind. Spent last week in S. America with a bunch of corn and bean farmers, so maybe I had to much Chilean beer. Then when I got back, decided to finish the brake off.
Thanks, have one shipping to me.
Old Feb 2, 2006 | 12:21 PM
Nate, I am just glad it was something easy. When I first read it I thouht you ment the rod on the master cylinder for the rear brake was leaking. That would of sucked!
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
cornermike
Sep 10, 2015 08:30 AM
