raptor idles really fast
Old Feb 1, 2006 | 04:44 PM
farmerjohn's Avatar
Default raptor idles really fast
my raptor idles really fast now. the choke is pushed in like normal but when i pull it out it idles slower and stops
Old Feb 1, 2006 | 06:40 PM
Raptor149's Avatar
sounds like your carbs probably need a good cleaning. That, and your choke plunger probably needs adjusting.
Need more info to diagnose:
airbox mods?
pipe?
jetting?
submerged lately?
Old Feb 1, 2006 | 10:44 PM
wshrdskin's Avatar
Did you pull out the carbs to rejet, leaving the cables connected? If so, when you twisted the carbs over to get to the bowls you might have made a complete 360 and eventualy put it together that way. If not that, then did you do anything that required you to move, push, pull or anything like that on the throttle and or choke cables? When you turn the handlebars from side to side does the idle go up at all? If so you have twisted the cables or somehow they've gotten out of the correct routing from the handlebars to the frame. Just some things that might be a solution for you.
Old Feb 1, 2006 | 10:50 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
you may need to turn your idle screw....
Old Feb 2, 2006 | 01:50 PM
fizzak's Avatar
Check your choke valve it is probably sticking open. Mine rusted open and caused this. As you may know the choke is not really a choke but a simple enrichening valve. Make sure it is shutting completely. You cannot determine this by moving the lever, you have to take the cable off and move the plunger valve. Be very careful. The reason I am using Edelbrock now is because mine siezed in there from me trying to get it out. The plunger should slide right out. I had the same problem.
Old Feb 2, 2006 | 08:13 PM
farmerjohn's Avatar
weel it's either 0ne of 2 things. i rolled it on it's side and repalced the handlebars. i didn't really notice it until i replaced the bars though. i'll take it to the shop have them look at it. bout time for a sevice anyway
Old Feb 2, 2006 | 08:19 PM
Speedy2222's Avatar
if you replaced the bars you may have twisted the throttle cable then..
Old Feb 2, 2006 | 09:20 PM
wshrdskin's Avatar
Did you get the same bars? Same bend etc? Are they taller bars than stock? Sounds like a mis routed or extra tight cable due to a different bed or height of bar. Easy fix if you trace it down and reroute. No need to spend that kind of cash for somthing like this, imo.
Old Feb 3, 2006 | 01:15 AM
oscar660's Avatar
all of those things can do it, but when all my raptors started doing it and i couldnt figure out what was going on, well long story short the valves were bad out of adjustment for some reason this will cause the idle to go crazy
Firefighter400
Oct 8, 2022 06:38 PM
Cummins Driver
Sep 11, 2019 01:22 PM
black_thunder
Jul 22, 2015 06:01 PM
brad wheeler
Jul 13, 2015 11:19 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
