NEED HELP ASAP!!! Base gasket keeps leaking.
Old Feb 2, 2006 | 01:46 AM
RAWYFZ1973's Avatar
Default NEED HELP ASAP!!! Base gasket keeps leaking.
A friend of mine bought my DS and the base gasket keeps leaking. It is now on its second gasket in about 6 months and I was wondering if anyone has had this problem before or might know what is causing the problem. It is an 02.
Old Feb 2, 2006 | 01:57 AM
DuneMe's Avatar
Where is the oil coming out? Is it just coming out the front near the starter?
How's your crank-case breather look? Any kinks? When the bike is running are you getting much air out of it?
Old Feb 2, 2006 | 06:59 AM
RAWYFZ1973's Avatar
The oil is coming out on the right of the motor around the middle.
Old Feb 2, 2006 | 11:35 AM
BigDaddy331's Avatar
what gasket is he using?
What torque values have been used?
If he is using a stock base gasket, and stock values, he might have a warp somewhere.
Make sure everything is super clean, that there is no gasket residual, and that when putting the jug on he is not damaging the gasket at all.
If all this is being done, he might try using a little yamabond. This is not normal, and the Yamabond might be a good patch.
good luck
BD
Old Feb 2, 2006 | 01:05 PM
MrMeaner's Avatar
Hey Raw just a little history on that bike. When the cams were put in they had a local shop with a gasket cutter make one for time reasons. The second gasket was stock and it did not leak in stock form. I would bet the gasket was damaged when installed. Call the local shop and talk to Jeremy about it and see if he knows anything also. I hate to hear that
Old Feb 2, 2006 | 10:03 PM
RAWYFZ1973's Avatar
Thanks for all the input everyone we'll see what we can do. Meaner Carmine talked to Jeremy and he didnt act like he knew what it could be.
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
tysonbully
Sep 28, 2015 02:30 AM
