Fuel Air Mixture sensor?
Old Feb 4, 2006 | 06:31 PM
1STXTIMERX's Avatar
Default Fuel Air Mixture sensor?
I know K&N makes a fuel air mixture sensor, is this worth getting? Will the oil/gas mixture mess up the reading? let me know on your guys experience with such a device or any reccomendations
Old Feb 4, 2006 | 06:40 PM
OregonDunePatrol's Avatar
Consider the Innovate Motorsports sensors. http://www.innovatemotorsports.com/ . They work with 2 strokes.
Old Feb 4, 2006 | 09:04 PM
1STXTIMERX's Avatar
Hell yeah!! thanks, you got this tool?
Old Feb 4, 2006 | 10:30 PM
One of the places I work with has them in all of thier testing. I've done a lot of research, and from what I have seen, heard and read, these are the most durable and most accurate. There are a couple of different ways you can go with that company. You can get a hard mounted unit, with a digital gauge that you would put somewhere on your quad and get real time reading when you ride. But, you might consider a portable unit, that way you can test, then you dont have to leave it hooked up to sniff your exhaust all the time. If you do hook it up permanently, the sensor will eventually need to be replaced. The Bosch sensors are around $75 each. With a 4 stroke, and leaded gas, you will get anywhere from 50 to 500 hours of life. But, if you just use it to tune, that will be a long time.
PrairieDog126
Sep 12, 2015 06:53 PM
black798
Sep 9, 2015 07:42 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
