killswitch placement
Old Feb 5, 2006 | 02:31 PM
kyrebel's Avatar
Default killswitch placement
I have a 2000 325 magnum that i will be keeping at my lakehouse come spring.It wil;l be locked in the shed but I want to put a hidden killswitch somewhere on it.Which wire could i splice into to kill the juice to it even to pull start it.Thanks
Old Feb 5, 2006 | 02:33 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you could put a master shut off switch like some big equipment have. ild put it between the battery and starter my self
Old Feb 5, 2006 | 05:28 PM
kyrebel's Avatar
Well ...you can disconnect battery and it will start with the recoil starter.Anyone have another idea.Thanks
Old Feb 5, 2006 | 08:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
then trace the wires from the kill switch down to a place hiden from veiw and put a switch to disrupt the circuit and you'll have your extrta kill switch that only you know where it is.
Old Feb 5, 2006 | 08:44 PM
wayout's Avatar
that wouldn't stop somebody from stealing it,if thats what you tring to do........wayout, out.........
Old Feb 5, 2006 | 08:49 PM
kyrebel's Avatar
Old Feb 5, 2006 | 08:51 PM
kyrebel's Avatar
i think ill split the white wire with blue stripe going to coil to another toggle switch.i know it wont keep it from being taken but will keep it from starting.
Old Feb 5, 2006 | 10:11 PM
dontgetbehindme's Avatar
Just a sug. but if I was going to leave it for a while I would put some oil in the cyl. to keep it from rusting then i would put a dummy plug in it, beat the old electrode off. If you want to do something like that, it sure woundn't start.
Old Feb 5, 2006 | 11:53 PM
SportsmanEE's Avatar
Splice into a black wire and use the toggle switch to connect it to ground. That'll keep the CDI from firing.
f1100turbo
Jun 4, 2015 09:50 AM
lapeerbanshee
Jul 23, 2004 04:53 PM
hp703
Jun 21, 2004 11:33 AM
BritBoy
Oct 27, 2003 08:58 PM
Riceburnin
Mar 23, 2001 08:46 PM
