thinking of buying a 87 lt80 Help?
Hey all, I am thinking about buying a 87 Lt80 for my daughter for 750 and was wandering if there was anything special I should ask the guy or anything I should look for on it. Thanks for the help.
Corbett
Corbett
A cpl things. [img]i/expressions/face-icon-small-smile.gif[/img]
Wiggle the grab-bar side to side. Movement can mean new bushings or a simple bolt tightening.
Look for cracks in the engine cases especially in front of the front sprocket area.
Check the frame on the 2 tubes just in front of the motor and where the 3 frame rails come together under the motor.
For $750 you can't get hurt too bad but understand that the probobility of a bore/piston ($100-125) may be needed. Clutch maintenence is well warranted and may reveal 2 bearings bad ($20 each) and maybe the front clutch hub (variator) may be wore($45). While in there, 6 new rollers ($3-4. each) are in order as yours are prolly flat anyways (I recommend only installing 4 rollers).
[img]i/expressions/face-icon-small-happy.gif[/img]
Lt80, thanks for the help. It looks real good for an 87, still has the original tires on it. It has been garage kept since he had it and it shows. I checked it over pretty good and the only thing I found was that the starter does not work and the hood has a few small cracks where it attaches at the top. The starter relay clicks and I am getting power to the starter so I will need to rebuild the starter and since I just got done taking an electrical motors class and I was an automotive and industrial electrician since 1997 it should not be that big of a deal. I tried getting the starter out tonight but I just could not get that little booger to wiggle out, any help here would be greatly appreciated. It runs real strong and smokes only a little. It looks to me that the restrictor may still be in the pipe so I am going to look at that this weekend. My daughter and I are going to start adding some accesseries soon and I and going to go thru the clutch and ome of the motor items also. Once again thanks for the help.
Could be a cpl things.
The pull start may be hanging up. A lil lubrication may help.
Some don't use the cork gasket when installing the pull start. This wears the teeth on the pull start (they are plastic).
4 screws and it comes out for inspection. Should be able to figure this one out easy enough. [img]i/expressions/face-icon-small-smile.gif[/img]
The starter is a booger!! It will wiggle out. Stand the machine on the grab bar. That may help.[img]i/expressions/face-icon-small-smile.gif[/img]
Well, I got the starter out and what a pain in the a@@ that was. It would be a lot easier if there was a small notch in the case for it to slide out. After I got it out and apart it was very easy to see the problem, a burnt armature. I guess it could not be the easy thing, a set of brushes. Well off to eBay for a new starter. I have not messed with the pull starter yet as I do not want to completely break the LT, at least we can still use the pull starter for now. Thanks for the help so far and I am sure that I will be asking more as I start to mess with the clutch and other things. Once again Thank you LT80.
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
ranvette
Jul 4, 2015 06:13 PM
