05 grizzly good deal?
Old Feb 6, 2006 | 02:12 PM
NewUteMan's Avatar
Default 05 grizzly good deal?
Hi all,
As you can tell I am new to the site and have a few questions purtaining to purcahsing a Grizzly. I have a local 05 Grizzly that I looked at this weekend but have some concerns.
It only has 38 hrs and 290 miles on the bike and does looked clean but it didn't start when I got there. He told me he bought it in Dec 04 but since moved and it has been sitting in his garage for the last 6 months (it was his wifes who is about 55 and only used it to run dogs on their 200 acre farm...so he says). Anyhow the filter was soaked in gas and oil which could explain it not starting but I am do not know enough about these to know. All of the electronics looked normal and it sounded like it wanted to turn over but just wouldn't.
It has the ITP rims with 589's which are 27's as well and they came on it as he said it is a limited edition one. He also has a 48 inch manual plow that has never seen the snow and he paid 525.00 for. He is only asking $5,500 for it but my main concern was the bike not starting. It also had a low front right tire but that could just be from sitting for so long but he will have that checked and fixed if it does have a hole.
Am I being to cautious or should i just take it because of the deal and worry about these things later?
Thanks for any help anyone can provide and sorry if this is to basic of a question for the forums but I'm a newbie...
Old Feb 7, 2006 | 12:45 AM
MALAHATMAGUIVER's Avatar
That seems to be a good deal.Remove the air cleaner and see if it starts.If it hasn't been run properly over a period of time the carb could be gummed up with bad gas.Visually inspect the skid plates for marks.They mark very easily and tell a good story of abuse.The tires are after market.I've never heard of a SE coming with ITP's.All in all that sound like a good deal if you can get it running.
Old Feb 9, 2006 | 12:31 PM
Sluggo312's Avatar
I would want to know why the air filter is soaked with gas and oil. I have an 05 grizz, I only have about 800 miles on it but I've done my best to beat the hec out of the machine. I've never had gas or oil on my airfilter.
ask if you can take it to a Yamaha dealer to have it checked out.
Old Feb 9, 2006 | 12:52 PM
Hebs's Avatar
The gas on the filter is from trying to start it, and pumping the throttle... Remove the filter, spray a little starter fluid or carb cleaner in the air intake, and try to start it. Drain the gas, change the spark plug. Sounds like a good deal.
Old Feb 10, 2006 | 04:45 PM
NewUteMan's Avatar
I probably should have jumped on it when I had the chance but the not starting issue scared me. He didn't use it for 6 months and was cranking on it pretty hard to get it started so that could be where the gas etc came from. Anyhow i looked on saturday and called monday to buy and it was gone... I am back to square one...thanks all for the replies
Old Feb 10, 2006 | 06:17 PM
rockroller's Avatar
hi all need help from you all! i'm going to be buying a new bike grizz/kodiak. questions are is the grizz to big for the trails? will it lift up on the back wheeles or will the kodiak 450 with some effert ? NewUteMan here is y you should be happy you didn't get the bike . i have the offer brand new kodiak 450 for 5500 out the door. or the 660 for 6400 out the door and that's because of out of state taxes! question 2 has any one had probloms with the kodiak not being able to turn over the wheels in deep soup mud? question 3 can you kick the *** end around at all (either bike)? dealer said no but i don't think he even rides! what do you all think? what would the be best to just go out and ride trails mud and pulling logs around the yard! ?
Old Feb 10, 2006 | 07:45 PM
CobraR6's Avatar
Sounds like a good deal. I would go for it.
Old Feb 10, 2006 | 11:13 PM
wildwest1011's Avatar
It sounds to me that you want a sporty 4x4. One that can spit some stone, do some wheelies and get over mud/snow. Check out the wolverine 350 4x4.
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
