Raptor Clutch
Old Feb 8, 2006 | 01:20 AM
spitdirtcom's Avatar
Default Raptor Clutch
I jujst finished installing a new clutch. I know all the plates are in correctly and everything because it was working but I had to take it apart because it was leaking oil from the clutch case gasket. I have now put it back together, the clutch is super easy to pull. Is this because I have not added oil yet. I forgot if it was like this last time I put it all back to gether. As far as the clutch lever goes, I have the dot lined up with the mark on the case. All the slack in the lever is clockwise, Is that correct? There is no slack at all counterclockwise? Any help is appreciated.
Thank you
Kory
Old Feb 8, 2006 | 10:40 AM
Will the clutch feel totally easy to pull with out any oil in the case? Please help I just dont want to fill it back up with fluids before I am sure that it is right.
Thanks
Kory
Old Feb 8, 2006 | 05:39 PM
recon99's Avatar
sorry to tell you this, but you put something together wrong. If anything, it would be harder to pull without oil because of less lubrication.
Old Feb 8, 2006 | 05:51 PM
CTracingraptor's Avatar
you didnt align that piece you drop it from the top correctly. try it again.
Old Feb 8, 2006 | 07:07 PM
Raptor149's Avatar
yep. sounds like the actuator arm is not grabbing the rod in the center of the basket. took me a couple tries to get it aligned right.
Old Feb 8, 2006 | 08:16 PM
Do I need to take the case cover off again or can I just remove the circlip (retainer ring) on top of the actuator arm and adjust from there? Thank you for all your help.
Kory
Old Feb 8, 2006 | 09:32 PM
I got it, man that made it so much easier and really made feel stupid!!!!!!!!!!!!
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Sep 6, 2015 04:41 PM
cdstang
Aug 31, 2015 07:52 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
