Overhaul 2000
Old Nov 9, 2000 | 03:59 PM
AIRtime300ex's Avatar
This is my new project, the beginning of the end... I'm getting my 300ex in shape to sell, and it turns out its alot of work. Today i replaced the insides of the a-arms... boy did that help, no more sloppy a-arms. It looks so good right now i might not sell it for the kx250 i'm looking at, but anywhoo... when YOU buy a quad what do YOU look for??? What should i concentrate on fixing and replacing to insure a good sale?
Old Nov 9, 2000 | 05:01 PM
Pitbull's Avatar
It all depends on what you think needs replacing. What do you look for when you buy a wheeler? Bearings, Bushings, Good rubber, No cracked plastic, Brakes, no welds on the frame, if its been rebuilt if yes then what work was done. The bottom line is would buy your own machine the way its in. Hope this helps
99 400ex race ready
Old Nov 9, 2000 | 06:50 PM
94DGblaster's Avatar
plastic, play in the steering, shocks, tires, rims, leaking oil, ease of start up, seat, bars, grips, control levers, and bearings. No welding on frame, no cracks.
Thanks pretty much it
Old Nov 9, 2000 | 07:55 PM
DS650DAVE's Avatar
Along with above posts,I check for;clean air filter, fresh oil,strength of antifreze if H20 cooled,greased grease fittings,cables working properly,depth of tread on tires, shocks not leaking
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
