DMC
Old Nov 9, 2000 | 07:56 PM
hondaflyer400ex's Avatar
how much HP gain will I expect from a DMC exhaust and will it improve bottom end ??
400ex
Old Nov 9, 2000 | 10:30 PM
bigboy400ex's Avatar
CAN YOU SAY OVERRATED !!!!!!!!!!!
SAVE YOURSELF SOME MONEY BUY THE YOSHIMURA FULL SYSTEM MORE HP AND TORQUE THAN DMC ..................
Old Nov 9, 2000 | 11:01 PM
bigred250x's Avatar
like how much power from the yosh?
Old Nov 9, 2000 | 11:04 PM
1QuickEX's Avatar
I'd recommend a DMC, you gain 5 mph on top end.
Hey bigboy400ex, have you ever raced a 400EX with a DMC pipe? I bet you'd change your tune if you did.
Old Nov 10, 2000 | 08:58 AM
yes it has raced a 400ex with dmc .
with a differant more the same size rider ...with wheels of ground about 6-8 inches it stayed in front of the 1 with the dmc....on dyno made more hp and torque ...........
Old Nov 10, 2000 | 09:00 AM
not alot of differance in hp an torque bt it had more and is cheaper....more money for other performance mods...
Old Nov 10, 2000 | 09:01 AM
this was at haspin acres were the have DIRT DRAG STRIP ..........
Old Nov 10, 2000 | 07:54 PM
LDJ's Avatar
LDJ
The DMC Exhaust sysytem is the best performing exhaust for the 400EX. If you plan on building your EX, the pipe even works better. I guess the yoshi system would be good on a stock bike, but if you plan on building your engine at all, the yoshi exhaust does not flow well enough and you would be restricting your engine. Go with the DMC. I will have mine at the end of the month.
