800 EFI Top RPM's?
All 700 cc Rangers are EFI. Only the older 500s are carbo, with the newer ones going EFI as well.
As for the throttle adjustment, there is *some* adjustment in the cable. He also had to put washers behind the gas-pedal mount (just one per bolt for a total of four). Others will use a roll pin crimped around the cable to take up the slack.
Best thing to do is to check your throttle plate yourself. Take off the hose clamp and remove the boot. Then depress the throttle (on the handlebars for the quad or the floor for the Ranger) and see if it deflects all the way. If you can move it wider, that means you're not getting a full throw.
Rick
Rick
