clutch adjustment for 350es 2x4(pics)
Old Feb 10, 2006 | 09:01 PM
mykool61679's Avatar
Default clutch adjustment for 350es 2x4
some one told me you should adjust the clutch every other oil change, if true, were is this clutch located, and how often do you adjust/ is this difficult?
Old Feb 10, 2006 | 09:55 PM
1988TRX250R's Avatar
Adjusting the clutch is easy and should be part of your routine maintenance. The adjustment is on the front engine cover. You will see a nut w/ a screw in the middle along w/ the words decrease and increase stamped on the cover. Take a 14mm wrench and loosen the lock nut. Use a flat blade screwdriver and turn the adjustment bolt counterclockwise until resistance is felt. Now turn it back 1/4 turn and tighten the locknut. Thats all it takes.
ghost civic
Jan 15, 2020 07:43 AM
toonces
Aug 3, 2015 09:59 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
