simple help here
Old Feb 15, 2006 | 06:49 PM
lt230s4life's Avatar
Default simple help here
i had a 13tooth sprocket on my honda 250x and i put a 14 on it and i couldnt get the chain around the sprocket to fit so i took the case save off and it fits so is that right or should the case saver still be able to work on it.. thanks for any help
Old Feb 16, 2006 | 12:01 AM
1988TRX250R's Avatar
It is sometimes necessary to remove the case saver when installing a bigger sprocket. Do some checking around, there may be a different case saver you can buy for what you are doing. If not, its up to you if you want to risk your engine cases should your chain break or come off the sprockets.
Old Feb 17, 2006 | 10:08 AM
300exStroked's Avatar
I put a 14 tooth on my 300ex and I had to remove mine too
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Schneider
Jul 24, 2015 05:05 PM
Eaaicf
Jan 10, 2001 05:32 AM
