New owner needs help.
Old Feb 17, 2006 | 12:36 PM
MO23's Avatar
Default New owner needs help.
Hey, I just bought a used 2001 Sportsman 500 HO and I want to change the fluids. I don't have an owners manual, so I have no idea what I'm doing. How do you change the rear gearcase fluid? I found the drain plug, but not the fill hole. Also, can you use the same oil from the gearcase to fill the transmission? I checked the tranny fluid and it is low on the dipstick. One more thing, does the front and rear gearcase use the same fluid? I'm taking it out on it's first big trip this weekend and I wanted to have it ready to go....any advice is also appreciated as far as other things to change or check...(I've already got the oil covered) Thanks!!!
Old Feb 17, 2006 | 02:33 PM
MO23's Avatar
OK, I figured out that the tranny and gearcase are the same...Now, all I need to know is if you can use the same fluid in the front and back.
Old Feb 17, 2006 | 04:28 PM
polarpower's Avatar
The tranny/rear diff run a different oil then the front dif. The front I use 80w90 but the rear you use Polaris AGL I think thats what they call it. I tried running gear oil in the rear and it did not shift in and out of gear very easily. Also might want to change the front hub oil, you need specific Polaris oil for that also. Hope you enjoy your quad.
Old Feb 17, 2006 | 09:22 PM
NemadjiJim's Avatar
Go to the Polaris website and you can download it for free. I think there is a rider tab and then you can choose a Owners Manual or Parts Manual.
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
