'97 kodiak wont run
Old Feb 20, 2006 | 11:01 AM
buffdaddy's Avatar
Default '97 kodiak wont run
I have a '97 kodiak 400 and it is giving me problems starting/ running. If i choke it and hit the start button, it will crank and run for about 2 seconds and then die. it does that 15 to 20 times before it will finally crank with the choke off. then when it finally cranks with the choke off, I have to let it sit and idle for 4 or 5 minutes before I can touch the throttle, or it will die again. I thought it was a problem with the carb so I purchase a new one and put it on the machine. It still does the same thing. Anyone have an idea what the problem could be here??
Old Feb 20, 2006 | 11:32 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
i would say check your fluids, your wiring connections, and if it's not ANY of those, it is internal on the engine..
Old Feb 20, 2006 | 02:22 PM
hondabuster's Avatar
If its been awhile since the valves were checked, Youll probably find the intake valve clearance is too tight.
Or the mixture screw is too lean, or you have an intake leak.
RedRancher
Oct 15, 2020 01:45 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
