Speed Limiter on Kodiak
Old Feb 23, 2006 | 02:14 PM
DoubleH's Avatar
Default Speed Limiter on Kodiak
I was flipping through the owner's manual on my new Kodiak and I came to the section on the "speed limiter" which keeps the throttle from fully opening. The manual says not to open it past a certain point as it could cause damage to the throttle. Does anyone know if this is preset to the maximum appropriate setting? Or, is it some sort of speed limiting "larwyer" switch designed to protect them from me doing something stupid. I guess I'm just trying to figure out why (short of damaging my throttle) I wouldn't want this thing wide open.
Old Feb 23, 2006 | 03:24 PM
hondabuster's Avatar
Is it referring to the small screw, on the throttle houseing? Im not sure why they even do that, its a thing done on most kid quads, to limit how far they can move the throttle...why its on a 450 full size quad, im not sure.
I believe when its sticking out 1/2 inch, it allows ful movement,and i think it shows that in the manual too. To unscrew it past 1/2 inch, doesnt allow any further movement of the throttle (wide open is wide open), but you could stretch the cable or end up putting excessive wear on the throttle and cable.
Old Feb 23, 2006 | 04:45 PM
DoubleH's Avatar
That's the one. I just picked up the quad and was reading the manual at lunch today so I haven't had the chance to see what the factory setting was. I thought it was kind of an odd thing to have on a full sized quad myself.
Old Feb 23, 2006 | 05:02 PM
In the set up, it should be adjusted to give full travel.
Enjoy your new quad, and welcome to the forums
Old Feb 23, 2006 | 05:22 PM
Raptor350rider14's Avatar
take the cover off the throttle and check if u can hold it wide open u will clearly be able to see
Pehter
Oct 3, 2024 11:00 PM
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
YankeeRebel
Oct 6, 2015 06:44 AM
ReconBayou
Sep 23, 2015 02:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
