Need some help with Grizz charging problems
Old Feb 23, 2006 | 08:49 PM
josh1's Avatar
Default Need some help with Grizz charging problems
I am having problems with my Grizz not charging. I have checked the battery and it is good, as far as I can tell all connections are good. Now I'am till checking the stator. I had my ohm meter on it and I can't get a reading(I have it on the right setting). I'am checking under the gas tank where it plugs together. From my tests of idling and having the lights on while idling etc. I think it is charging. Could it be a weak charge?? Or if the stator is shot, it is shot and there is no in between?? Any help?? Thanks
Old Feb 23, 2006 | 09:08 PM
jaggers2e42's Avatar
no i think there can be a in between. are all your connection clean..before i tore it down i would have somebody check it for sure before i took it all apart.maybe you could tell them to check it and contact you before they go any farther.
Old Feb 23, 2006 | 09:10 PM
oh forgot it seems like yamaha has a bad problem with electrical...i had to put a new cdi on mine but it was so worth it.
Old Feb 23, 2006 | 10:23 PM
OGGYDOGGY's Avatar
I had the same prob. what is the reading at the battery when at an idle ? Mine was like 11.27v and when I turned the lights on it went down , even at a high rev. it would not charge the batt. enough. If you have the manual follow it , and you will find out what is wrong.I had the feeling my stator was bad and it was after spending all kinds of $$ on good parts.I saved a lot of $ buy replacing it myself. After replacing it my volts went to over 14V at an idle . This is about the 3rd one I have heard of that has gone bad on the Grizzlys . There is a variance in the #s or an in between from what I have learned, mine may have gone bad do to the middle gear seal leaking engine oil , I may have over heated my stator if that makes sense , the seal is on order. good luck.
200es
Jul 19, 2015 04:50 PM
toonces
Jul 16, 2015 03:19 PM
toonces
Jul 15, 2015 07:14 AM
toonces
Jul 11, 2015 12:01 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
