Sprocket to Spline Looseness - Raptor660
Old Feb 26, 2006 | 02:28 PM
N2flips's Avatar
Default Sprocket to Spline Looseness - Raptor660
I have an 03 Raptor660 and noticed the other day that the rear sprocket has some looseness on the axle splines. I check the brake disk and it was slightly loose as well. Is this normal? The rear end is not loose, I put the bike on a stand and wiggled the rear end. It does not have any slop. Also, what is the size of the axle nuts? Looks like 50mm.
Old Feb 26, 2006 | 03:26 PM
warriorboy22's Avatar
that happened to my bike and it was my lock nuts were loose so it gave the caliper and sprocket play but it wasnt loose enough to move my axle. tightened them havnt had a problem since
does your rearbrake work because mine didnt.
Old Feb 26, 2006 | 09:43 PM
N2flips's Avatar
warriorboy22
Rear brake works fine.
Something I forgot to mention. It only does it when the bike has been ridden for a while. Anyone know the torque value for the axle nuts for the Raptor660?
Old Feb 26, 2006 | 11:13 PM
KevinHarper06's Avatar
Look in your manual should have the torque ratings listed. Go to the part where it talks about maintence or somthing on the axle etc and should have them listed.
blueandy88
Sep 7, 2020 03:11 PM
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
blueandy88
Aug 30, 2015 08:26 PM
