replacement clutch bar
Old Feb 26, 2006 | 07:39 PM
farmerjohn's Avatar
Default replacement clutch bar
i need a replacement clutch bar, just the metal part you pull on. i did a search but came up empty
thanks for any help.
Old Feb 26, 2006 | 10:02 PM
farmerjohn's Avatar
i think i found some
here's another question
can i take just the lever part off of a different clutch? the only reason i'm asking because the raptor 350 has the parking brake on the clutch mount. i'm trying to explain it the best i can.
Old Feb 26, 2006 | 10:18 PM
recon99's Avatar
Oh the clutch lever, I couldn't figure out what a clutch bar was. The lever itself is the same on most yamahas, I know for a fact that the 660 lever is the same, and that a warrior's lever is the same, but i'm not sure about the others.
Most guys just ditch the stock clutch perch and parking brake setup, they end up causing more trouble than they're worth, and the stock perch and lever's pivot points wear out quickly, and make the clutch pull hard and notchy. I have a picture of my perch in my picture gallery \/ \/, it works and looks much better than the stock one, and you don't have to worry about the useless sensors causing trouble.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
