TCS Shocks
I just bought a pair of TCS standard travel shocks that were originally mounted to a YFZ. I am putting them on a Raptor. The fittings at the end of the braided line connecting the shock to the Rezzie needs to be rotated about 90 degrees so I can mount it to my frame properly. What is the best way to do this? Will I need to bleed the system after loosening the fitting?
Also, There is play in the shock (Left and right). It is at the top mount inbetween the bushings where it is able to turn. They are rubber bushings so it may be normal, but I have no clue. I will try and post a picture in my profile so you can see.
Any help is greatly appreciated!
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
