stuborn swing arm
Old Mar 3, 2006 | 11:09 PM
200Xjae's Avatar
Default stuborn swing arm
Hey guys, this swing arm on my 85 200X is really pissin me off. The pivot bolt is stuck, I mean STUCK. I need to remove the swing arm but the bolt wont budge, I have tryed just about everything. Any ideas???? Please.
Old Mar 3, 2006 | 11:35 PM
JkAss's Avatar
Bigger hammer. After soaking it with something like WD40 or Yeild and let it sit for about 15 minutes. Don't forget to leave the nut on the end of the bolt so you don't screw up the threads on the end of the bolt when you beat the crap out of it.
Old Mar 4, 2006 | 12:04 AM
200Xjae's Avatar
Yea I know what you mean about the big hammer and WD-40 that has been my last two day attempt. One guy said that they like to seize up and you have to cut them off.....um no i would rather not if I can help it.
Old Mar 4, 2006 | 12:26 AM
JkAss's Avatar
You could try dry ice . Try to freeze as much of the bolt as possible. Personally, I wouldn't try a torch in that area.
Old Mar 4, 2006 | 02:39 AM
HondaAtcRoxz's Avatar
My swing arm bolt was stuck and i used a slege hammer. I stripped almost all the threds out of the bolt and the nut and mushroomed it out bad. I soaked it in wd40 and then took an impact wrench and turned it as much as i could and sprayed it more. I let it sit over night and it came right out pretty easy.
Old Mar 10, 2006 | 01:13 AM
200Xjae's Avatar
Thanks for all your help guys.
Old Mar 10, 2006 | 12:26 PM
Did you get it?
Old Mar 15, 2006 | 02:26 AM
200Xjae's Avatar
It's still on their. I have not had much time to mess with it, although I did manage to hit so had that the nut is stuck as well now. Beautiful!
Old Mar 17, 2006 | 11:37 PM
dragracer789's Avatar
You will def. need to pound it hard!, and be your going to need a new one too.
Old Mar 18, 2006 | 01:08 AM
BeerSmurf's Avatar
Ok, I've been down this road.
The problem is that the swingarm bolt is rusted to the spacers and bearings.
Here is what works for me.
You need an air hammer/rivet gun and a chunk of aluminum plate.
Use the chunk of aluminum between the air hammer/rivet gun and the bolt or you will ruin the bolt and the tool.
You will need to hold the sacrificial piece of aluminum with some pliers or vice grips so you don't hurt your fingers.
Drive the bolt just a tiny bit then drive it back the other direction.
Do this several times and it will move more and easier each time.
A big hammer just ruins the part, but the small blows of the air hammer/rivet gun are able to overcome the corrosion.
Good luck.
fd24
Jan 16, 2019 08:59 AM
Jul 28, 2015 12:12 PM
Bell21
Jul 28, 2015 06:52 AM
VRRRRT
Jun 27, 2015 09:38 AM
ragewraps
May 27, 2015 08:07 AM
