83-85 200x and 200m engines
Nothing in the bottom end is the same other than a few fasteners. The gear ratios are also different.
The only differences in the top end is the cylinder on the X has larger cooling fins, the camshaft has a different profile, a higher compression piston in the X, and the rocker cover on the X doesn't have the cable operated decompression lever.
Same porting and same valves.
07-30-2015 09:39 AM
KimSJoh
14
07-18-2015 07:20 PM
