Predator 90 lighting
Old Mar 9, 2006 | 10:24 PM
fj40's Avatar
Default Predator 90 lighting
I just bought my son a new polaris predator 90 ATV. I would like to put another set of lights on the quad for riding at night. I see a lot of after market kits on the web. I'm wondering if the the electrical system can handle two 35 watt halogen lights? I found the older Predators have a 35 watt stator? Did Polaris upgrade the wattage in the 2006 model? Does anyone have a good website to buy them?
Old Mar 9, 2006 | 11:11 PM
spike99's Avatar
Found this cut / paste info on another forum...
For those of you with the light upgrade off the 06 model year 90 Pred and of course the 06 bubbas too, I searched hi and low and have finally found and tested a higher output bulb that plugs right in to the factory socket. Goto your local auto store and pick up a Sylvania bulb set number 921 ( LL, if you want the Long life version due to the always one mode of the lights). They are rated at 16 Watts per bulb as compared to the measely 5 Watts of the stockers. I have put 27 riding hours on these and have yet to have a problem with the stator or the housings themselves. As you might guess there is a night and day difference between the two. My son can now CLEARLY see at night and is loving life. They are a larger bulb but dont worry they fit perfect. Have fun and let me know what you all think yourselves. Wildbill- check them out, would be perfect for the new one you have for the little ones.
If wondering, the Stator in the Polaris 90s will only support lights with "combined wattages" up to 32-34 watts. If you go above 32 watts (say, 2 x 20w bulbs), it will eventually drain the battery. Thus, no lights at all - unless you recharge the battery by turing the lights off.
Hope this helps.....
Old Mar 10, 2006 | 12:28 AM
watzupdog's Avatar
fj40 I see you found your way over here, looks like spike fixed you up.
Old Mar 10, 2006 | 01:05 AM
fj40's Avatar
Thank you very much! I will give them a shot. I don't know why Polarais thinks there doing us a favor. Brighter lights in dusty conditions and at night are safer than the stock light wattage they provide. Thanks
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Steeldon
Sep 9, 2015 09:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
