yamoto 150 04 model
Old Mar 13, 2006 | 06:21 PM
sumo's Avatar
Default yamoto 150 04 model
hi i wonder if any one has had this same problem. i have a yamoto 150 04 model and when started some times it would start up with a miss fire and then it would go and it will be ok. but the other day i startedit and it ran for a while ticking over and then it stalled and i tried to start it again and it would not go so i tried again and then i thought i would try look at spark and it did not have one ? have tried every conection and cleaned them all even the stater plate and inner magneto but still no spark i changed the plug for a ngk and it has run fine till now. i have checked the coil for live pulse when turning over with a power probe and it did not light the probe up. dont know what else to try please can some one help.
Old Mar 15, 2006 | 07:11 AM
looneytunsman's Avatar
Hows it going the first thing you should try is the ignition module located at the left rear frame side , it kinda looks like a back-up beeper module . There should be two black modules the one with the back-up beeper only has two wires and the ignition module has five or six if im not mistaken.Other then that your looking for a broken wire somewhere. take care, LTM
Mar 21, 2016 06:30 PM
Whitelx1
Oct 2, 2015 10:55 PM
kbazzy
Sep 26, 2015 11:26 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
