450R stalling
Old Mar 13, 2006 | 10:05 PM
Rise400ex's Avatar
Default 450R stalling
Hey guys,
Just bought a brand new 450R with eletric start. I have run about 8 gals of gas through it. The last time I was out riding it would stall about every 2 out of 10 times when I would go to give it some gas. It is not while I am in gear or a clutch problem. It will do it even in neutral but only when you go to snap the throttle. I plan on taking it back to the dealer but just want to get some feedback from you guys first. Has anyone else had this problem with their 450R and if so what did you/dealer do to correct the problem?
Old Mar 13, 2006 | 10:18 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
I had that problem after I put in the Hotcam and rejetted mine.
It would do it to me when I rode in the Eastern Washinton desert but no other place that I ride.
I think it may be the air/fuel mixture screw.
Old Mar 13, 2006 | 10:21 PM
Rise400ex's Avatar
My quad is still all stock!
Old Mar 13, 2006 | 11:17 PM
TractorPacker's Avatar
Do you have a balloon?
It does have an air/fuel mixture screw stock, though!
Old Mar 14, 2006 | 07:21 AM
Rise400ex's Avatar
Can you or anyone tell me where that is on the carb. I have been unable to get a manual for it yet!
Old Mar 14, 2006 | 09:01 AM
HondaMan440ex's Avatar
Yes, I had that probelm when i first got mine as well. I took it back to the dealer and all they said was to adjust the Idle speed. It has not stalled out once when it gets warm like it used to. just make the quad idle a little bit faster and you should be okay. hope this helps
Old Mar 14, 2006 | 02:46 PM
hondabuster's Avatar
Sounds like the mixture screw is a bit on the lean side. Its on the bottom of the carb body, just forward of the float bowl. Go out, for richer.
Old Mar 14, 2006 | 04:50 PM
JSsDS's Avatar
Its there all right but good luck adjusting it. Honda used a screw with a special head that requires a special tool to turn it. You can turn it without the tool but the area is very tight and you will not get anything else in there. From what I can tell, you will have to loosen the carb and turn it enough for better access to the screw. Or just remove the carb altogether. The tool comes in the HRC kit but I adjusted the screw according to the direction in the kit while the carb was in my hands. Even with the tool it looks like a chore to adjust without removing anything.
Maybe somebody has a better idea that they can post.
Old Mar 14, 2006 | 09:03 PM
Rise400ex's Avatar
Ok, I think I see it.I had to use a mirror to see it because it is facing down in front of the carb bowl and is shaped like a letter D and is recessed slightly in the hole that it sits. Is this the mixture screw that I am looking at?
Old Mar 15, 2006 | 12:30 AM
JSsDS's Avatar
Thats it
