2000 AC500 Manual Shift selectable 4x4???
I did a search an got no clear answer on this question. I know for a fact that the 2000 model 500 manual didn't have selectable 4 wheel drive. I was wondering if there was ever a successful mod or write up that would allow me to make it selectable 4 wheel drive. I saw 1 post mentioning switching in a King Quad diff, but I didn't see any mention of what tear KQ to get the parts off of??? Any help would be great.
RyanRX7,
I think I have seen a front diff locker made by Warn on an old king Quad which should work as a diff lock on your AC.
The 4 wheel selection lever made for the 250/300 may work if you have the part that it hooks to already on your front diff. It disengages the front dif totally.
I guess since there are similarities between the King Quad and AC 500 you could always swap out the diff housing or the diff all together.
hope this helps
SJ
hope this helps
SJ
naw, the part you're thinking of is for the 250 and 300 models. Thanks for the reply though
Yup, I had the same idea......but the front diff is different in the auto. Therefore the piece that the 4 wheel select handle on an auto would hook to isn't there. The diff also attaches differently to the drive output. The auto uses a universal joint, the manual doesn't. Thanks for the suggestion though.
Upon fruther research I could swap out the front diff and purchase the selector handle. But there is a piece I found the auto to have as well that I do not. They call it a "secondary gear shift assembly" it looks like a little plunger button. Anybody with an auto or 2001 model manual know what this is or what it does? I found that this part is exclusive to the models with selectable 4 wheel drive, I just don't understand where it is located on those models or what it does. Thanks
Njrider1230
Jul 29, 2023 05:16 AM
tank10rnk
Aug 10, 2015 08:19 PM
